mod_minifrontpagepro_j3 error
Hi, I post this also in my Free tread.
After installing mod_minifrontpagepro_j3 I got an white front- page. - 0: The image does not exist -
On the same domain. The mod_minifrontpage_J3 is working fine out of the box.
I choose my own overall header picture and indeed in the thumbnails folder there is one generated image.
What went wrong?
I installed on Joomla 4.0.3 - mod_minifrontpagepro_j4 without any problem.
Summary:
On the same domain:
The free version is working fine, as expexted.
The pro version gives a white page.
I also removed the mod_minifrontpage_J3 for avoid a possible conflict.
Regards,
milian
4 years 11 months ago #1 by Max
Hi millian,
I got 403 error when trying to access the administrator page. Can you check it please?
https://www.dropbox.com/s%2Fu3yzx5fpfy574ip%2F403%2520forbidden%25202021-10-01%252022-21-34.png?raw=1
4 years 11 months ago #2 by TemplatePlazza
Sorry. You have access now.
Admin was protected with an IP limitation.
Hoe you find it.
,Milian
4 years 11 months ago #3 by Max
I filled in some site details for you.
4 years 11 months ago #4 by Max
Hi millian, It's strange. When I tried to change the category to Archief 2016 then the module is working properly. I think this is something related to external image inside the article, because minifrontpage free version doesn't process image from external site.
I need to make some test in the article but it will need to modify the content. Can I make some test by modifying this article's content ? : Verhuizing en de winkel (ja30-bp.maxfolmer.nl/administrator/index...e&layout=edit&id=636)
4 years 11 months ago #5 by TemplatePlazza
Yes, you can make any modification you need.
This is my test site for the real site when everything is working fine, i install it on the production site:)
regards, Max
4 years 11 months ago #6 by Max
