Change Title from h4 to h2
How to change <h4 class="mfp_infinity_title">Title</h4> to <h2 class="mfp_infinity_title">Title</h2>
4 years 11 months ago #1 by Jose
Hi, You can do that via template override. Please open file infinity_ajax.php
At lines 74-78 you will see this code :
            <a href="<?php echo $item->link; ?>" itemprop="url">
                <?php echo JHtmlString::truncate(strip_tags($item->title), $title_truncate);  ?>
            </a>
        </h4>
change that into
            </a>
        </h2>
4 years 11 months ago #2 by TemplatePlazza
Ok thank you, I made the change from h4 to h2.
I have a problem with the "Read More" override:
If I make the change indicated for href the error page appears: This site can’t be reached because it redirects to a link without domainname.com
<a href="/<?php echo $item->link; ?>" style="font-size:16px;font-weight:700;color:white;background:blue;display:inline-block; padding:5px 7px;">Read More</a>
If I suppress the slash in href it shows the article on the home page, although the url shown is the correct article address.
<a href="<?php echo $item->link; ?>" style="font-size:16px;font-weight:700;color:white;background:blue;display:inline-block; padding:5px 7px;">Read More</a>
What is the solution to show the article in the correct menu item?
4 years 11 months ago #3 by Jose
This is likely a known issue with default Joomla itemid behaviour. Please try to create a hidden menu item (can be category / blog page layout) for your content category where the module showed. We have youtube tutorial for that issue you can check :
4 years 11 months ago #4 by TemplatePlazza
Excuse me, could you give me an explanation with more details, since I don't really understand what to do?
4 years 11 months ago #5 by Jose
I made a solutions salad that solved the problem:
1. I used your override solution without the slash:
<?php } ?>
<a href="<?php echo $item->link; ?>" style="font-size:16px;font-weight:700;color:white;background:#083061;display:inline-block; padding:5px 7px;">Leer Artículo completo</a>
2. Change the alias to the original menu item "Cuba" to (Alias: noticias-de-cuba-original) Hidden, Articles » Single Article, and "unpublished"
3. I created a new menu item:
Cuba (Alias: cuba-noticias) Articles » Category Blog and published to replace the original menu item Cuba.
Although I don't know exactly which change or changes solved the problem after many tests
4 years 11 months ago #6 by Jose
