Minifrontpagepro and joomla 4
I have just purchased the minifrontpagepro module and I have a problem with the creation of the default thumbnail. I am under joomla 4 and if I change the default image the thumbnail is not created and the display is faulty.
I bought your module in particular for the infinity layout and I discovered that it was not compatible with joomla 4. Do you know when you will have fixed the bugs in this theme?
Best Regards
4 years 8 months ago #1 by FRICH
  • Posted by TemplatePlazza (5456) Offline
Do you use JCE?
Yes unfortunately the compatibility issue still not fixed yet in Joomla 4.x We're still trying to find a workaround but we can't say exact date for that.
4 years 8 months ago #2 by TemplatePlazza
Thank you for your reply,
No I don't use JCE but TinyMCE
Best regards
4 years 8 months ago #3 by FRICH
Umm the module shourl be working properly with tiny MCE.
I also have re-checked this and it's working properly at my end. Can you try to remove all images located under this folder (to remove all thumbnail caches) and then refresh your home page :
../images/thumbnails/mod_minifrontpagepro
4 years 8 months ago #4 by TemplatePlazza
I had already tried to erase the thumbnails in the folder.
If I do so while changing the default thumbnail the site crashes (0-The image file does not exist.)
If I do this while I leave the original default thumbnail it works and the thumbnails get created.
I stopped the additional plugins, I don't put any other module on the page and I even put the Cassiopeia template back. But it does not work...
4 years 8 months ago #5 by FRICH
Can you share temporary access to your website so I can have a look on it directly? If you can, you can share it in the Your Site Details tab below. Only you and support staffs who are able to see it.
4 years 8 months ago #6 by TemplatePlazza
