Mini Frontpage Pro Formatting/Link
- Posted by Peter (8) Offline
1) How can I get the article title to link to the assigned link in the "Images and Links" settings of the Article instead of the article details?
2) Is it possible to show html (small image w/ link) in the Intro Text? - It shows in the details page but not the intro text (and it is within the intro chars limit)
Thanks.
4 years 11 months ago #1
by Peter
Thanks.
Hi, You can do that all by adding template override actually. Please follow this video if you don't know how to do that
and for your questions :
https://www.dropbox.com/s%2Fl287gjxhtks2x2x%2Farticles%2520edit%2520-%2520j39%2520-%2520administration%25202021-11-25%252007-12-12.png?raw=1
if so, you can add this code in your template override :
change that to
4 years 11 months ago #2
Did you mean you want to use Link A, Link B, Link C instead of single article link?1) How can I get the article title to link to the assigned link in the "Images and Links" settings of the Article instead of the article details?
<?php $articleLinks = json_decode($item->urls); echo "<a href=".$articleLinks->urla.">Link A</a>"; ?>after you have created template override, find this part :2) Is it possible to show html (small image w/ link) in the Intro Text? - It shows in the details page but not the intro text (and it is within the intro chars limit)
echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);change that to
echo $item->introtext;Please Log in or Create an account to join the conversation.
For #1 - can I add <?php $articleLinks = json_decode($item->urls); echo "<a href="/.$articleLinks->urla.">Link A</a>"; ?> anywhere in the override code?
4 years 11 months ago #3
by Peter
You can add that code anywhere inside the loop (foreach ($list as $item) : )
4 years 11 months ago #4
anyway you can give me an approximate code line # so I'm in the right area?
4 years 11 months ago #5
by Peter
You can put it at lines 207
https://www.dropbox.com/s%2Fni47q7hiimkd8xs%2Fdefault.php%25202021-11-25%252010-13-12.png?raw=1
it will show the link after the introtext
4 years 11 months ago #6
