Minifrontpage sort and order
Thanks for the great Minifrontpage extension.
However, I would like to be able to sort with the end of publication and be able to choose the sort order separately.
Does the pro version do this?
4 years 10 months ago #1 by Roger Guillet
Hi, did you mean : 'Finish Publishing' ?
If so, no you can't do that in the Pro version, but I'll consider to add that option in the next pro update.
4 years 10 months ago #2 by TemplatePlazza
Thank you to consider this need, many criteria and separate sort order will be great.
I'm waiting for.
4 years 10 months ago #3 by Roger Guillet
Hi rogerguillet , Version 2.0.0 is available now with Finish Publishing option. www.templateplazza.com/items/mini-frontpage-pro
Here are the changelog:
Version 2.0.0 - 01-07-22
* Changed codebase for Joomla 4 version. Now Minifrontpage Pro for Joomla 3 and 4 use the same installation file (Unified version)
- Infinity Theme now supports Joomla 4
+ Added New Article orderings : Featured first to make Featured Article is sticky, Backend ordering and Finish Publishing
- Fixed issue when image path is not exist
4 years 4 months ago #4 by TemplatePlazza
