Maximum size of the thumbnails generated
How to limit the maximum size of the thumbnails generated by Minifrontpage Pro to save excessive resource use on mobiles?
Notes:
All images used in my intro articles are 460x246px and the generated thumbnails are 1080x576px
I'm using Theme: Infinity, Number of Column: 3, Next Item Trigger (Ajax): Infinite Scroll, Theme Skin: card.min.
4 years 9 months ago #1 by Jose
Hi, I think, because your original image size is small, then I think it's better to use the original image size settings (or smaller), with no retina support, so then the module will generate the same size with the original one.
https://www.dropbox.com/s%2Ft5vxxojtzaihuy4%2Fmodules%2520mod_minifrontpagepro%2520-%2520j39%2520-%2520administration%25202022-01-11%252011-42-26.png?raw=1
4 years 9 months ago #2 by TemplatePlazza
Ok, Thank you very much for your fast support
4 years 9 months ago #3 by Jose
