Issue with Whatsapp Multi Agent
Hello, I just updated Whatsapp multiagent. It is corectly displayed on the website, but if I click or set auto open, it doesn't work.
I have seen that it could be an issue with jquery that have to be activated on the template, but I don't really see this option in my template's config.
4 years 9 months ago #1 by Chris Tian
Hi I can see that your website is already calling jQuery but maybe the problem is about the script load ordering. I'd suggest you to install this extension extensions.joomla.org/extension/jquery-easy/ to fix the problem.
4 years 9 months ago #2 by TemplatePlazza
I juste updated admin access for you. Thanks
4 years 9 months ago #3 by Chris Tian
Hi, I have edited the greeting message and removed some the empty characters (line break) and seems it works now. can you check it please?
4 years 9 months ago #4 by TemplatePlazza
