Using animated banners inside of Carousel banner
We have a couple of animated GIF banners that run on rotation alongside other banners that are static images. I've noticed that if the animated banner happens to be the first to load then the animation runs, but only for that one time through the sequence. I'll provide an URL in the details tab for you to look at.
Is there any way to force the module to reload the image and allow it's full animation play each time it comes up in the sequence?
4 years 8 months ago #1 by Chad Criswell
Hi, I'm not really sure about that, but if you know about javascript you can try one of solution proposed in here stackoverflow.com/questions/16919862/jav...uing-script/16919953
4 years 8 months ago #2 by TemplatePlazza
