Mini FrontPage Pro got error display in article order: "Recently Touched First"
Hello, I'm running my website Joomla 4 in localhost (and using JCE Editor). I just bought Mini FrontPage Pro and tried to use this function in "Order: Recently Touched First". I got these errors in front page:
Warning: foreach() argument must be of type array|object, bool given in C:\wamp64\www\...\components\com_content\src\Model\ArticlesModel.php on line 713
Warning: foreach() argument must be of type array|object, bool given in C:\wamp64\www\...\modules\mod_minifrontpagepro\Helper\MinifrontpageproHelper.php on line 158
Warning: foreach() argument must be of type array|object, bool given in C:\wamp64\www\...\modules\mod_minifrontpagepro\tmpl\default.php on line 125
Please help. Thank you!
4 years 7 months ago #1 by Victor N
Hmm it looks like there's an issue with the position Recently Touched First with Joomla 4. Can you use other option instead? maybe Recently Added First, that will give the same result as 'touched first' option.
4 years 7 months ago #2 by TemplatePlazza
Okay, I’ll use another option for it instead. Hopefully this issue will be fixed in next update
4 years 7 months ago #3 by Victor N
