Mini Front Page error
- Posted by Gina Geick (2) Offline
Unsupported operand types: string * int
File: /home/xxxx/public_html/modules/mod_minifrontpagepro/Helper/MinifrontpageproHelper.php
Line: 260
Tried both default theme and collage - no go. This is on PHP8 - which seems to be the problem.
4 years 6 months ago #1
by Gina Geick
Line: 260
Errrr.. I spent many hours to investigate the issue with focusing PHP 8 compatibility just to found out that the issue is because you have entered the wrong format for Thumbnail Height
You have entered 'auto' while the correct format must be a number.
I have changed the value of Thumbnail Height from your backend and the module seems working good now. Please check.
4 years 6 months ago #3
