WhatsApp Multi Agent
  • Posted by LUIZ CARLOS FERNANDES (2) Offline
We installed WhatsApp Multi Agent, not working, we use joomla4
ginendo.com.br
Thank you so much!
Luiz Fernandes
4 years 6 months ago #1 by LUIZ CARLOS FERNANDES
Hi Luiz, I found that the module is not assigned into any module position yet. I have published the module into debug position, and it looks like it's working good now. Please check.
4 years 6 months ago #2 by TemplatePlazza
Hi, thank you!!!
In which position should I place the module, I have other templates to use, on other sites, I didn't find this guidance in the manual!
Yours sincerely,
Luiz Fernandes
4 years 6 months ago #3 by LUIZ CARLOS FERNANDES
Hi, Basically you can assign the module in any position. By I'd recommend you to use the most bottom position such as 'debug' position
4 years 6 months ago #4 by TemplatePlazza
