Call to a member function modify() on bool 0
I have this problem only when i add an agent :
ERROR 0 : Call to a member function modify() on bool
4 years 5 months ago #1 by MB INFORMATIQUE
Hi, Can you check it again? I have added a fix the module installation on your website
4 years 5 months ago #2 by TemplatePlazza
Great what is it ? Thanks for all
4 years 5 months ago #3 by MB INFORMATIQUE
The problem is that for some servers the DST php function can't work properly (still have no idea what the causes it). Therefore I have to disable the function on the the module's code.
4 years 5 months ago #4 by TemplatePlazza
Thanks what do the dst function ?
4 years 5 months ago #5 by MB INFORMATIQUE
It's Daylight Saving Time
4 years 5 months ago #6 by TemplatePlazza
