Minifrontpagepro Columns number
Hi, and thankyou in advance.
I encounter this problem: I setted Minifrontpagepro module "Ultime COMUNICAZIONI a FAMIGLIE e ALLIEVI" on Default theme, one column. The result is correct only if the display is large. If the window scale to tablet format: two columns appear. See the referenze link added.
Can you help me, please?
Roberto
4 years 4 months ago #1 by Roberto
Hi RobGal, Can you check it again?
4 years 4 months ago #2 by TemplatePlazza
Wow, that's fine !!!
Was I doing something wrong?
Rob
4 years 4 months ago #3 by Roberto
No, It's indeed there is missing condition for tablet scale when column is set to 1, so I changed the code via template override
4 years 4 months ago #4 by TemplatePlazza
Thanks a lot !!! great and precious.
Roberto
4 years 4 months ago #5 by Roberto
