Thumbnails not generated
The Related Items Extended module doesn't create the thumbnails
I've checked and i've seen that there is no "thumbnails" directory into my images directory
When i try to create manually, it doesn' allow me to do
So what can i do???
4 years 2 months ago #1 by Garamond United
Hi Simply try to reinstall the module. It will try to re-create the folder if no thumbnails folder found
4 years 2 months ago #2 by TemplatePlazza
I've checked that via Filezilla there's no thumbnails directory...
But if i check via Cpanel the thumbnail directory is there...but all the generated thumbnails are gray...
4 years 2 months ago #3 by Garamond United
Hmm, maybe it's something related to your server cache function / feature. Anyway what joomla and Related Item Extended version do you use?
4 years 2 months ago #4 by TemplatePlazza
Unistalled and reinstalled...same thing :(
4 years 2 months ago #5 by Garamond United
Do you use JCE?
4 years 2 months ago #6 by TemplatePlazza
