After upgrading website crash
- Posted by Jose (41) Offline
After upgrading to your last version of Mini FrontPage Pro for Joomla 4, my website crashed. Now in the Joomla Home Dashboard appears 127 overrides to check.
cubanamericanvoice.com/
I have not made the upgrade in patriademarti.com/ waiting for your solution
4 years 3 months ago #1
by Jose
Hmm It looks like because of template override you have before. Minifppro 4 indeed have a major codebase change to follow compatibility of Joomla 4. Let me check it out. Will back to you soon.
4 years 3 months ago #2
Hmm I found so many template override files for minifrontpage on your website. Can you tell me which overrides you actually used? Infinity and default?
4 years 3 months ago #3
Only Infinity and default, similar to those used on the website patriademarti.com
4 years 3 months ago #4
by Jose
Hi jtusa, I have fixed it. Can you try it again now?
These are what I did :
1. I backed up your template override files for default and infinity
2. I added some necessary update to override files.
3. I deleted the override folder for minfirontpagepro
4. I re-created override for minifrontpage
5. I restore the overrides to your website.
4 years 3 months ago #6
