html tags
How to allow HTML taps in mfp_introtext in the default theme to show links?
4 years 3 months ago #1 by Jose
Hi, you can do that by creating a template override (if you don't know how to create it you can follow this video
) then change then change this part :
echo JHtmlString::truncate($item->introtext, $introtext_truncate, true, false);  ?>
into
echo $item->introtext;
4 years 3 months ago #2 by TemplatePlazza
In what file i can find the line ?
4 years 2 months ago #3 by Jose
Thank you very much, I found this on line 202, now is showing the link tags
4 years 2 months ago #4 by Jose
Now the default card appears as duplicates one line without introtext and other with the correct introtext showing the link tags, see attached screenshot or view datepalmsnursery.com/shop
4 years 2 months ago #5 by Jose
Sorry for delay, I missed your reply:(. It's because you post the image inside the body. Try to change previous part into this code :
<?php echo strip_tags($item->introtext,'<img />'); ?>
4 years 2 months ago #6 by TemplatePlazza
