Page Peel showing little picture icon
Hope you can help me quickly to solve this. I have changed the page peel images accordingly to the suggested size (500x500 and 80x80) and uploaded to the server. The problem is that there is a small picture icon right in the middle. What have I done wrongly and how do I get rid of it?
You can check here: www.navigonlp.com/Enneagram/enneagram-coaching.html
Also when the peel open the big picture has a fram at the bottom of it. Is it possible to somehow get rid of it?
Thank you in advance for your support.
Have a great day,
Carsten
13 years 6 months ago #1 by Carsten
Mmm...I don't see any problem you mentioned above. It looks like you have solved it, haven't you?
13 years 6 months ago #2 by erwinschro
Thanks for the quick reply.
No I haven't solved it. You mean you can't see the little favicon right in the middle of the small and the big picture? I just checked with my colleague in the office and they can see it to. I have attached two screen shots with the problem. It's right in the middle as if there is another picture which isn't loading.
13 years 6 months ago #3 by Carsten
Ok here an additional update. I found out where the error is coming from.
I tested it in Firefox and to my amazement I also can't see it. So I guess the problem is (again) coming from Chrome. The screenshots I sent where made from a Chrome window. Even the little frame which you can see in the screen do not appear in FireFox. Any ideas?
13 years 6 months ago #4 by Carsten
Mm.. can you manage to edit this file /modules/mod_pagepeel_banner/tmpl/default.php at this line
<img src="<?php echo $modulebase; ?>assets/<?php  if($peeltheme == 1){ echo "bg.png"; } else { echo "bg-dark.png";} ?> " alt="" />
edit it into
<img src="<?php echo $modulebase; ?>assets/<?php  if($peeltheme == 1){ echo "bg.png"; } else { echo "bg-dark.png";} ?>" alt="" />
see the difference? there's a space just before the last quote mark for src property. It's been added to the html in Chrome.
Let us know the result then
13 years 6 months ago #5 by erwinschro
Great this solved the problem with the little favicon and the pagepeel is now also showing nicely. However, now the text I had written on the left part of the big picture has disappeared:). I guess the peel was never meant to written on.
Just to let you know, this is what the line looks like on my side. Notice there is no / in it at the beginning like in the code you posted. Does it make a difference?
13 years 6 months ago #6 by Carsten
