carouselxt e infinity model
- Posted by Bn Design (10) Offline
Hey.
I want to make my thumbnail clickable.
Clicking on the image will redirect you to the article.
3 years 9 months ago #1
by Bn Design
I am using minifrontpage.
Template (model) carouselxt e infinity
Joomla4
3 years 9 months ago - 3 years 9 months ago #3
by Bn Design
Joomla4
Last edit: 3 years 9 months ago by Bn Design.
Hi I'm assuming you enable the setting Thumbnail Mode to Thumbnail as Background, because because if you set it to Thumbnail Image then the image is linking to article.
So, basically you can do that via template override
open the file infinity_ajax.php then add the codebefore the code and add the colsing before
3 years 9 months ago - 3 years 9 months ago #4
<a href="<?php echo $item->link; ?><div class="mfp-col-xs-12 mfp-col-sm-6 mfp-col-md-<?php echo 12/$infinity_num_column;?> mfp_infinity_item"></a><?php
endforeach; ?>
Last edit: 3 years 9 months ago by TemplatePlazza.
