Carousel image background when Resize and scale fit
  • Posted by fc@mediamakers.ch (5) Offline
Impossible to find which style should I modify to change the background colour behind the thumbnails... It is now black and I would like to change this colour.
Thanks so much in advance !
Best regards
Francois
3 years 8 months ago #1 by fc@mediamakers.ch
Hi, Can you share your website url so I can see it directly?
3 years 8 months ago #2 by TemplatePlazza
Sure !
mediamakers.ch/sites_clients/cuche/
(site in early state, not even in alpha)
3 years 8 months ago #3 by fc@mediamakers.ch
Hi, I think this is because of the difference in ratio that you use for the size and width of the thumbnail. You use a size that is square (width = height), while the original image is a rectangle. So the module automatically adds a black background. What is the Resize method setting that you use? Is it Crop Resize?
3 years 8 months ago #4 by TemplatePlazza
Resize...
3 years 8 months ago #5 by fc@mediamakers.ch
How about to use Crop Resize?
3 years 8 months ago #6 by TemplatePlazza
