Minifrontpage and HTML tags
- Posted by Marina W (2) Offline
Hello. I just installed the module for the first time and I noticed it strips the html tags included in the intro. Is there a way to change this?
Thanks for your help!
3 years 8 months ago - 3 years 8 months ago #1
by Marina W
Last edit: 3 years 8 months ago by Marina W.
Hi, You can do that via template override. ( If you don't know how to create template override you can follow this video :
Then find this code :
change that to
3 years 8 months ago #2
echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);change that to
echo $item->introtext;
Thank you!
The line of code I had to replace was a bit different:
but you pointed me in the right direction and I was able to identify it and make the replacement.
Great extension, thanks!
3 years 8 months ago - 3 years 8 months ago #3
by Marina W
echo JHtmlString::truncate($item->introtext, $introtext_truncate, true, false); but you pointed me in the right direction and I was able to identify it and make the replacement.
