You can edit them from /language/en-GB/en-GB.tpl_deals_plazza.ini file OR you may copy that file, rename it to your specific language file xx-XX.tpl_deals_plazza.ini and place it under your specific language folder /language/xx-XX/ where xx-XX is your language code.
13 years 6 months ago #2
