WhatsApp Multi Agent failed in graphic setting
I installed WhatsApp Multi Agent with joomla 4.x and when all agents are offline the setting appears wrong. How can I fix the error?
3 years 7 months ago #1 by &Consulting
Hi, Can you tell me your website url to check?
3 years 7 months ago #2 by TemplatePlazza
il sito web in fase test è il seguente:
www.bancheefinanza.it/b/
3 years 7 months ago - 3 years 7 months ago #3 by &Consulting
Last edit: 3 years 7 months ago by TemplatePlazza.
Hi, Please do not post sensitive information in this public forum. If you want to send credentials you can send it via email to us.
By the way, I have visited your website and found the problem is because the module style is overrided by your template's css.
I have added this code to the CSS adjustment tab :
.wavatar_img {display:inline-block!important;}
​​​​​​​and looks like it's working properly now. Please check.
3 years 7 months ago #4 by TemplatePlazza
It is now seen with overlaid icons. All agents are disabled except the first one and should not be seen overlapping like this. If they still have to see each other it's much better if they're sorted vertically like when they're enabled and connected.
3 years 7 months ago #5 by &Consulting
The overlapped icon is indeed the standard look, as you can see in this demo page : demo.templateplazza.com/joomla/index.php/email-form-fallback
I'm not really sure what you're trying to get, but you can always modify the module look by adding css code in CSS Adjustment tab to get the look you want.
3 years 7 months ago #6 by TemplatePlazza
