Joomla 4 - Error with saving module after Joomla Upgrade
- Posted by Kae Wan (11) Offline
I upgraded to Joomla 4.0 and upgraded the Carousel Banner to the Joomla 4 Version. Since the upgrade, I have not been able to create a new Carousel Banner module. I am getting the following error below.An error has occurred.
Do you have any idea why this might be occuring please?
Thanks,
Kae
3 years 7 months ago #1
by Kae Wan
Call stack#FunctionLocation1()JROOT/libraries/src/Form/FormField.php:12582Joomla\CMS\Form\FormField->validate()JROOT/libraries/src/Form/Form.php:12293Joomla\CMS\Form\Form->validate()JROOT/libraries/src/MVC/Model/FormModel.php:2194Joomla\CMS\MVC\Model\FormModel->validate()JROOT/administrator/components/com_modules/src/Model/ModuleModel.php:9285Joomla\Component\Modules\Administrator\Model\ModuleModel->validate()JROOT/libraries/src/MVC/Controller/FormController.php:6446Joomla\CMS\MVC\Controller\FormController->save()JROOT/administrator/components/com_modules/src/Controller/ModuleController.php:2507Joomla\Component\Modules\Administrator\Controller\ModuleController->save()JROOT/libraries/src/MVC/Controller/BaseController.php:7308Joomla\CMS\MVC\Controller\BaseController->execute()JROOT/libraries/src/Dispatcher/ComponentDispatcher.php:1469Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch()JROOT/libraries/src/Component/ComponentHelper.php:38910Joomla\CMS\Component\ComponentHelper::renderComponent()JROOT/libraries/src/Application/AdministratorApplication.php:14311Joomla\CMS\Application\AdministratorApplication->dispatch()JROOT/libraries/src/Application/AdministratorApplication.php:18612Joomla\CMS\Application\AdministratorApplication->doExecute()JROOT/libraries/src/Application/CMSApplication.php:27813Joomla\CMS\Application\CMSApplication->execute()JROOT/administrator/includes/app.php:6314require_once()JROOT/administrator/index.php:320 Call to a member function test() on bool
Thanks,
Kae
Hi Kae,
I think it's because the installed version you have in your installation is still the joomla 3 version of the module. Please re-download and reinstall the joomla 4 version
3 years 7 months ago #2
Sorry I didn't see that you have installed the J 4 version in your previous post. But still I'm unable replicate your problem (please see this
video
). The version for Joomla 4 is working properly with me. Can you try re-download and reinstall the module? I have pushed a minor update today.
3 years 7 months ago - 3 years 7 months ago #3
Last edit: 3 years 7 months ago by TemplatePlazza. Reason: added video link
Hi.
I tried uninstalling and re-installing with the new version and its still showing the same error.
Would it have anything to do with the database collation?
Here's the Joomla Debug - J! Info tab details below.
=====================Joomla! Version4.0.4PHP Version8.0.28IdentityuserResponse200TemplateatumDatabaseServermysqlVersion10.5.18-MariaDB-0+deb11u1Collationutf8mb4_general_ciConn Collationutf8mb4_general_ci
Here are the Joomla Debug Request tab details below.
=====================$_GET$_POST$_SESSION=====================
What are your thoughts?
3 years 7 months ago #4
by Kae Wan
array:4 [
"option" => "com_modules"
"layout" => "edit"
"client_id" => "0"
"id" => "0"
]array:5 [
"jform" => array:16 [
"title" => "test"
"params" => array:26 [
"target" => "1"
"count" => "5"
"cid" => "0"
"tag_search" => "0"
"ordering" => "0"
"column_settings" => "0"
"num_column" => "1"
"custom_num_column" => array:5 [
"__field10" => array:5 [
"breakpoint" => "320"
"col" => "1"
"gutter" => "0"
"edgepadding" => "0"
"note" => "For smartphones"
"__field11" => array:5 [
"breakpoint" => "567"
"col" => "2"
"gutter" => "5"
"note" => "For landscape smartphones"
"__field12" => array:5 [
"breakpoint" => "768"
"col" => "2"
"gutter" => "10"
"note" => "For tablets"
"__field13" => array:5 [
"breakpoint" => "992"
"col" => "3"
"gutter" => "15"
"note" => "For desktops"
"__field14" => array:5 [
"breakpoint" => "1200"
"col" => "4"
"gutter" => "20"
"note" => "For large Desktops"
"autoplay" => "true"
"autoplay_timeout" => "3000"
"anim_in" => "tns-fadeIn"
"anim_out" => "bounceOut"
"anim_speed" => "1000"
"gutter_size" => "20"
"edge_padding" => "0"
"border_radius" => "0"
"css_adjustment" => ""
"layout" => "_:default"
"moduleclass_sfx" => ""
"cache" => "1"
"cache_time" => "900"
"style" => "0"
"module_tag" => "div"
"bootstrap_size" => "0"
"header_tag" => "h3"
"header_class" => ""
"showtitle" => "1"
"position" => ""
"published" => "1"
"publish_up" => ""
"publish_down" => ""
"access" => "1"
"ordering" => "1"
"language" => "*"
"note" => ""
"assignment" => "0"
"assigned" => array:52 [
0 => "159"
1 => "173"
2 => "169"
3 => "170"
4 => "171"
5 => "172"
6 => "174"
7 => "167"
8 => "160"
9 => "177"
10 => "178"
11 => "197"
12 => "179"
13 => "180"
14 => "181"
15 => "198"
16 => "728"
17 => "570"
18 => "150"
19 => "137"
20 => "176"
21 => "183"
22 => "175"
23 => "199"
24 => "168"
25 => "729"
26 => "352"
27 => "353"
28 => "705"
29 => "461"
30 => "611"
31 => "114"
32 => "118"
33 => "119"
34 => "110"
35 => "590"
36 => "354"
37 => "129"
38 => "356"
39 => "462"
40 => "730"
41 => "592"
42 => "726"
43 => "707"
44 => "589"
45 => "426"
46 => "166"
47 => "149"
48 => "374"
49 => "551"
50 => "612"
51 => "668"
"rules" => array:4 [
"core.delete" => array:10 [
1 => ""
9 => ""
6 => ""
7 => ""
2 => ""
3 => ""
4 => ""
5 => ""
10 => ""
8 => ""
"core.edit" => array:10 [
1 => ""
9 => ""
6 => ""
7 => ""
2 => ""
3 => ""
4 => ""
5 => ""
10 => ""
8 => ""
"core.edit.state" => array:10 [
1 => ""
9 => ""
6 => ""
7 => ""
2 => ""
3 => ""
4 => ""
5 => ""
10 => ""
8 => ""
"module.edit.frontend" => array:10 [
1 => ""
9 => ""
6 => ""
7 => ""
2 => ""
3 => ""
4 => ""
5 => ""
10 => ""
8 => ""
"module" => "mod_carousel_banner"
"client_id" => "0"
"treeselectfilter" => ""
"task" => "module.apply"
"return" => ""
"ea4ac099d1a3d8c2a11c8087b38f42ec" => "1"
]array:2 [
"PHPDEBUGBAR_STACK_DATA" => []
"joomla" => "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"
]What are your thoughts?
It looks like you're using the earlier version of joomla 4 (4.0.4) that still has some issues. Please update your Joomla 4 to the latest version first.
3 years 7 months ago #5
I have upgraded to the latest Joomla 4 version (4.2.9) and the same issue is still occurring.
I have found the actual line of code where it breaks. I tried commenting that line of code and and the form saves fine. Obviously, this is not a permanent fix.
Here is the code that breaks the Carousel Banner form from saving below.
Code:
try {
// Run the field validation rule test.
$valid = $rule->test($this->element, $value, $group, $input, $this->form); // This is where the Carousel Banner module save method breaks down.
} catch (\Exception $e) {
return $e;
Can you check if there is something that can be rectified in the Carousel Banner module code itself please?
Thanks,
Kae
3 years 6 months ago #6
by Kae Wan
Code:
try {
return $e;
Thanks,
Kae
