WhatApp Multi Agent SEO Issue
  • Posted by Francesc Sanabria Roca (1) Offline
Aloha,
I recently discovered that the header for the pop-up window and the names of each listed agent are listed in the source code as <h1> and that's a problem for SEO since that makes for excessive H1 tags. Is there a way to get them changed to a <div>, <span> or <p> maybe with a class for the H1 styling? This is detrimental as it shows up on every report I send out.
Please advise,
// Francesc
3 years 6 months ago #1 by Francesc Sanabria Roca
Hi Francesc,
Sorry for delay in responding.
You can do that via template override. If you don't know how to create template override you can follow this video :
You can replace all <h1> tag on the default.php file
3 years 6 months ago #2 by TemplatePlazza
