Collage and clickable images
- Posted by Janusz (3) Offline
I need to make my thumbnail clickable with an article url.
Any clues?
3 years 6 months ago #1
by Janusz
Any clues?
Hi, sorry I don't really understand your question, do you want to use a collage theme by switching the thumbnail mode option to the 'thumbnail image' instead of 'thumbnail as background'?
3 years 6 months ago #2
Yes, I am. But there is only a title clickable and redirecting to specific article. I need whole image area clickable - click on an image and redirects to specific article.
I just need any clue where and what I should change/add in the module code.
3 years 6 months ago #5
by Janusz
Hi, You can modify the look of the module without changing the original code by creating template override. You can follow this video if you don't know how to create template override
You need to edit the collage.php file and move this link part (that currently wrapping the article title):into the container of the article item.
Unlike other themes, collage has a codebase that is quite complicated and complex, but if you are familiar with php, it shouldn't be that difficult.
3 years 6 months ago #6
<a href="'.$item->link.'" itemprop="url"> Unlike other themes, collage has a codebase that is quite complicated and complex, but if you are familiar with php, it shouldn't be that difficult.
