HTML Tags being stripped
I saw another post that pointed out a template overide to restore HTML Tags to the articles.
I removed this (line 202) - /***echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);***/
and added this in its place - echo $item->introtext;
I had email addresses at the beginning of the article and they still are not active...anything else I need to do?
URL - aif-proindoorfootball.com/front-office.html
Trey
3 years 2 months ago #1 by trey braid
Hi trey, I've taken another look at it on my localhost and confirmed that it's functioning correctly. The issue might be related to the override being placed in the wrong file. If you're using the Infinity theme, the file you should be editing is "infinity_ajax.php." You'll find the relevant code around line 116.
3 years 2 months ago #2 by TemplatePlazza
I made the change in that file ultimately; but, when I did the whole article text was then displayed.  Is there a way to make the change and still retain the Introtext Characters Limit?
Trey
3 years 2 months ago #3 by trey braid
Gi Trey,
Ok, try this one
$introtext = strip_tags($item->introtext, '<a>');
$truncatedIntrotext = JHtmlString::truncate($introtext, $introtext_truncate);
echo $truncatedIntrotext;
3 years 2 months ago #4 by TemplatePlazza
Thank You, much appreciated!!!
Trey
3 years 2 months ago #5 by trey braid
Np. Glad it works
3 years 2 months ago #6 by TemplatePlazza
