Carousel banner
- Posted by Excalibur (19) Offline
I also want to use the carousel banner to display our sponsors on our homepage. But for whatever reasons (I may be blind), I can't find any option to select the carousel style (e.g., carousel banner 3). I looked in component banner -> category/images/clients.. I looked in module carousel banner but nothing. And of course the banner is not shown on the homepage. Only the title is visible, when I do activate it.
What do I miss and where can I adjust it? I uploaded two images as examples. Those are visible under the component banner and I have mapped them to the same category, which is used in the module.
my website is new.skg-zh.ch
The carousel banner is configured to appear on every page at the bottom.
Thanks for some guidance.
3 years 2 months ago #1
by Excalibur
Really strange, are you sure you have mapped the module to the correct banner category? Can you please post a screenshot of your module and banner settings?
3 years 2 months ago #2
Last edit: 3 years 2 months ago by Excalibur.
do you require more information? I deinstalled the Hot Carousel Banner this morning, guessing that it might be a conflict between different modules. I also tried a different template position but it didn't help.. next thing will be to reinstall the module from scratch or on a "naked" joomla site.
3 years 2 months ago #6
by Excalibur
