Issue with intro text display
- Posted by jeff popkin (10) Offline
Hello, I had installed your minifrontpage to use, and went ahead and had my boss purchase the pro version. It is a great tool for article display. I do have one small issue I am hoping there is a quick fix for. I have been using PageBuilderCK to create my articles. Sadly if I enable for intro text to display (and I do have everything set in article with the readmore), it is showing the styling code from pagebuilderck rather than the actual contents within the article.
3 years 1 month ago - 3 years 1 month ago #1
by jeff popkin
Last edit: 3 years 1 month ago by jeff popkin. Reason: embeded images cause lines of code, changed to attached
Can you please share your website's URL with me so that I can take a look?
3 years 1 month ago #2
I included it in a screenshot to show you. The website is bostoneventguide.com however, the site is live and I do not want to leave it up there. I do not mind enabling it for you to see if I knew a specific time you were going to look at it, but with new and returning clients visiting the site throughout the day, I do not want something that could give a "malicious code" vibe to our viewers being live on the page. In fact, I will go ahead and make a page that is not accessible through a menu and create a new module for it that shows the error I am speaking of. I think that will be best.
3 years 1 month ago #3
by jeff popkin
I enabled a module on this page that will show you. This page is Live, but one of the least visited links.
bostoneventguide.com/event-list
3 years 1 month ago #4
by jeff popkin
I have checked downloaded PagebuilderCK, and tried it out myself. The code you mentioned appears to be parameters generated by PagebuilderCK, which are stored in the introtext. Minifrontpage retrieves the introtext as raw text. The easiest way is to disable introtext. But if you're still want to disaplay introtext, you can modify the theme code of the minifrontpage theme using a template override. If you don't know how to doing template override you can follow this video
So, after implementing a template override, please locate this part of the code:
then change to :
3 years 1 month ago - 3 years 1 month ago #5
echo JHtmlString::truncate(strip_tags($item->introtext), $introtext_truncate);then change to :
$new_intro = $item->introtext;
$pattern = '/.*\{width:\d+%;\}/U';
$new_intro = preg_replace($pattern, '', $new_intro);
echo JHtmlString::truncate(strip_tags($new_intro), $introtext_truncate);
Last edit: 3 years 1 month ago by TemplatePlazza.
