CarouselXT no stack and slideshow
When I use any of the carousel theme's, the articles included are not grouped together but are placed on top of each other. Also there is no possibility to use the (automatic) slideshow.
See screenshot:
These two articles should be viewed as one carousel.
Could you help me?
3 years 1 month ago #1 by skloer
Can you please provide me with your website's URL so I can take a look?
3 years 1 month ago #2 by TemplatePlazza
You can find it here: mbber.nl/
Look for the articles beneath the word 'Wetenschap'
3 years 1 month ago - 3 years 1 month ago #3 by skloer
Last edit: 3 years 1 month ago by skloer.
It appears that jQuery library is not enabled in your template. Does your template have an option to enable jQuery from its settings page?
3 years 1 month ago #4 by TemplatePlazza
Unfortunalty i'm not seeing this option. My template uses bootstrap.
3 years 1 month ago #5 by skloer
Ok, you can add it via a template override. Please watch and follow this video:
. After you have successfully created a template override, please open the file carouselxt.php. At line 18, after this code:
use Joomla\CMS\Helper\TagsHelper;
add the following code:
use Joomla\CMS\HTML\HTMLHelper;
HTMLHelper::_('jquery.framework');
3 years 1 month ago #6 by TemplatePlazza
