I BOUGHT "Mini Frontpage Pro" EXTENSION BUT IT GIVES ME ERROR DURING INSTALATION
- Posted by Christopher (2) Offline
I bought the above said extension and try to upload it to my website but I get an error. I'm using joomla 4.3.4
Attached herein is the error I'm getting.
Please tell me what to do
3 years 4 weeks ago #1
by Christopher
Based on the error message, it seems that you uploaded the file minifrontpage_pro_unzip_first.zip directly. As its file name suggests, you should extract the file first. Upon extraction, you will discover these files:
documentation.pdf -> This is the documentation file.
mod_minifrontpagepro_j3_j4.zip -> This is the installation file. Upload this file <---
mod_minifrontpageprok2_j3.zip -> This is the installation file for K2 version
3 years 4 weeks ago #2
Thank you for your reply Max. I have extracted it as you instructed. But I'm still getting the same error. Please see the attached
3 years 3 weeks ago #3
by Christopher
Strange, are you able to install any other modules/extensions? Because the error message states that it cannot create a folder, which is probably a permission problem
3 years 3 weeks ago #4
