Floating buttons : How to display 2 modules ?
I cannot find how to display 2 different floating modules.
I have 2 modules with 2 different css classes and positions, but the modules stay at the same position, I am unable to place one of them below the other. Is there a solution to do that ?
Thank you for your help.
2 years 7 months ago #1 by solsix
  • Posted by TemplatePlazza (5444) Offline
Can you tell me what your website URL is so I can check it out? Also why do you want to have two floating buttons on the same page?"
2 years 7 months ago #2 by TemplatePlazza
Thank you for your answer,
I have one button "?" linked to an internal page (glossary) and one button with social networks sharing.
The url is dgi.imagomage.fr (the 2 modules are not in the homepage)
2 years 7 months ago #3 by solsix
The module is not designed to be published twice on the same page, but I think it's possible. Although I haven't tested it yet, you can try creating two instances of the module and apply a negative margin-top to the first instance to prevent them from overlapping
2 years 7 months ago #4 by TemplatePlazza
Well, I tried but it doesn't work...
2 years 7 months ago #5 by solsix
Can you tell me what you have done so far and what errors you have encountered? Could you also point me to the page where you have published the modules
2 years 7 months ago #6 by TemplatePlazza
