Minifrontpage pro not displaying images
- Posted by Jeffrey Kiefer (12) Offline
I just installed the pro version and it is not saving the images to the mod_minifrontpagepro image directory. Only the default images are displayed. When I delete the default images from the directory the correct images do not show up instead the default images are used again. Is there something I am overlooking?
3 years 2 weeks ago #1
by Jeffrey Kiefer
Hi, can you please provide me with your website's URL so I can take a look?
3 years 2 weeks ago #2
This is the second license I purchased for a new website project. I had the same issue with the first one and you resolved it. I build on a subdomain if that makes any difference. Here is a link and login for the website. It is not public yet.
3 years 2 weeks ago - 3 years 2 weeks ago #3
by Jeffrey Kiefer
This message contains confidential information
Last edit: 3 years 2 weeks ago by TemplatePlazza.
Hmm, it looks like you use 3rd party extension to add article's image (Blog Media) to your website so the module unable to find the image because it neither in intro image, fulltext or in the article body. Can you tell me what extension is it?
3 years 2 weeks ago #4
