WhatsApp Multi Agent crashing site after update
Hi, sorry for the trouble. Do you have any template override before? If yes then please open your template override file, change the part modWhatsAppAgentHelper with WhatsAppAgentHelper
2 years 11 months ago #1 by TemplatePlazza
Ah, I see. Yes, the latest version has indeed undergone major changes to remove the jQuery dependency. Okay, please send me your override file via email to support at templateplazza dot com, and then I will send you the new override file.
2 years 11 months ago #2 by TemplatePlazza
Also please let me know which Joomla version you are using.
2 years 11 months ago #3 by TemplatePlazza
Done. The file has been sent
2 years 11 months ago #4 by TemplatePlazza
