Thumbnails are bad quality
I've got problem because Minifrontpage PRO is creating low quality thumbnails. I've set quality to maximum, but its very bad.
What can i do to increase quality of generated thumbs?
2 years 10 months ago #1 by Vjekoslav77
Hi, it's probably because you set the thumbnail size to be larger than the actual image size in the article. Minifrontpage uses the standard Joomla class JImage to process images, and JImage generates a blurry image when the image settings are larger than the actual image. There's an explanation about this in the documentation.pdf. Have you read it?
2 years 10 months ago #2 by TemplatePlazza
