Minifrontpage not loading on home page
I have just installed Minifrontpage (ver 4.0.1) on my test system. Joomla 4.4.1 & PHP 8.1.25
I could not get it to work with my RocketTheme template Xenon (Gantry 5) IE nothing would load on the home page, so I changed the site to use Cassiopeia theme for all pages, unpublished Minifrontpage, then checked the home page loaded OK. It did.
I then published Minifrontpage setting its position as “Sidebar-left”. Everything else as default.On loading the home page, the following is returned. See attachment.
Any help on what I have done wrong would be appreciated.
Colin
2 years 10 months ago - 2 years 10 months ago #1 by Colin
Last edit: 2 years 10 months ago by Colin. Reason: Removed image and added as attachment
Hi, based on the error message, it indicates that you don't have the GD library for PHP. This library is required to generate image thumbnails. How did you set up your web server? The GD library is typically available by default in most web server setups.
2 years 10 months ago #2 by TemplatePlazza
System is IIS on my Windows laptop. PHP was manual upgrade a few months back. Path to the PHP folder is correct.
Checking IIS manager php_gd2.dll is an enabled extension, it is listed in php.ini [ExtensionList] and the file exists in \ext\ folder.
2 years 10 months ago #3 by Colin
I don't know why that happened; perhaps there's a missing configuration on your system.
Anyway, is this a local development setup? If so, I'd recommend installing a simpler local web server application, such as WAMP or XAMPP
2 years 10 months ago #4 by TemplatePlazza
OK
Will give a WAMP install a try.
Cheers
2 years 10 months ago #5 by Colin
Ok
2 years 10 months ago #6 by TemplatePlazza
