Module title visible with theme carousel (even if should be hide)
- Posted by Pierfrancesco (6) Offline
I have the same ISSUE described here:
templateplazza.com/forums/technical-supp...theme-carousel#15967
But unfortunately the Workaround proposed:
adding this code to the CSS Adjustment tab: .mfp_carousel_skin_card .mfp_block_title {display:none;}--
do not work for me.
JOOMLA Version 5.0.3
MiniFrontPage version: 4.0.1
Any other idea ?
THX
2 years 8 months ago #1
by Pierfrancesco
do not work for me.
Any other idea ?
THX
simmetriainstitute.it/it/
THis is the test site . But in HOME page there is the ISSUE...
2 years 8 months ago #3
by Pierfrancesco
Hi, try this one
2 years 8 months ago #4
.mfp_carousel_skin_default .mfp_block_title {
display:none!important;
This new code seems to works fine.
THX a lot.
But the bug will be solved in the next realease ?
If YES, when ?
P.
2 years 8 months ago #5
by Pierfrancesco
THX a lot.
If YES, when ?
P.
Hi, it's not actually a bug but a feature. Some users want the module title to be placed symmetrically inside the module wrapper on the left side to achieve a more symmetrical look, especially when there are a lot of modules published on one page. Typically, having the default Joomla module title published will leave margin below it. So, with this option available, you can choose between having the standard Joomla module title or having the module title inside it. Please refer to the screenshot to see what I mean.
You might be wondering why we didn't make this option (to hide and show) available in the module backend. We decided to keep the module parameters tidy and simple, avoiding bloating them with too many options. If you want to make some simple custom adjustments, simply add CSS adjustments. If you need more advance layout adjustment, then use template override
2 years 8 months ago - 2 years 8 months ago #6
Last edit: 2 years 8 months ago by TemplatePlazza.
