Whatsapp Captcha
- Posted by Pete (1) Offline
I purchased the Whatsapp Module and so far I'm quite happy with it. One thing I notice is that I'm getting a lot of spam from the offline contact form. I have reCaptcha enabled but since it's using v2 it's pretty much useless these days. Would it be possible to get an update for reCaptcha v3 support or any other modern captcha solution?
Thanks!
2 years 8 months ago - 2 years 8 months ago #1
by Pete
Thanks!
Last edit: 2 years 8 months ago by Pete.
Hi Pete, I believe reCAPTCHA v2 is still relevant for contact forms to prevent bots. However, thank you for your suggestion; I will consider adding v3 (but can't give you ETA yet). Btw I'm just wondering, isn't the contact form in the module not appearing all the time?
2 years 8 months ago #2
- Posted by sachin singh (1) Offline
