Disable connection to googleapi
  • Posted by Däumling Andreas (1) Offline
is it possible to easily disable the connection between Google and the Module and be sure that an update of the module will not override it? We need to do it because of german gdpr   .
At the moment I disabled it with editing the mod_floating_buttons.php (/*$doc->addStyleSheet('fonts.googleapis.com/icon?family=Material+Icons');*/)
2 years 6 months ago - 2 years 6 months ago #1 by Däumling Andreas
Last edit: 2 years 6 months ago by Däumling Andreas.
Hi, yes, you can do it like that. Alternatively, you probably want to download the CSS and font from:
fonts.gstatic.com/s/materialicons/v142/f...IuiaDsNcIhQ8tQ.woff2
and then make them local.
2 years 6 months ago #2 by TemplatePlazza
