Keyworks instead of taps
Is there a workaround for filtering options to use keywords instead of tabs? Using infinity Theme and card.min as Theme Skin
2 years 5 months ago #1 by Jose
Hi Jose, did you mean meta keywords? No, it's not available in Minifrontpage pro, but it is available in the Related Extended Module (but no Infinity theme), so the functions do not overlap with each other.
2 years 5 months ago #2 by TemplatePlazza
