do I need to update??
- Posted by david ascher (11) Offline
I'm using Mini Front Page Pro v2.2.2 with Joomla 5.1.2 and haven't noticed any problems. Is there a good reason to update to the latest version of MFPP?
2 years 3 months ago #1
by david ascher
Hi david, there have been some improvements made since version 2.22. While we highly recommend updating to the latest version, if you are not experiencing any issues with the current version and do not need the features available in the latest update, it is perfectly fine to continue using the older version. You may find that you will really need to update later when a fully compatible version with Joomla 5 (without BC) is released
2 years 3 months ago #2
Hii David, it's Backward Compatibility. Here is the explanation
magazine.joomla.org/all-issues/february-...should-switch-it-off
2 years 2 months ago #4
Of course. I don't know why that didn't come to mind immediately.
Thank you again for the rapid reply.
2 years 2 months ago #5
by david ascher
