Error displaying the module
- Posted by SK UP Olomouc (5) Offline
Hello, after updating the Mini Front Page Pro module to version 2.5.0, the following error message appears on the frontpage: 0 - Class "MinifrontpageproHelper" not found With version 1.5.0 everything worked without problems. Joomla version 4.4.8 Thank you for your help. Peter
2 years 2 months ago #1
by SK UP Olomouc
Hi, do you have any template overrides for Minifrontpage Pro? There have been some changes in the theme code between the old version and the latest one. I think you should update the template override as well
2 years 2 months ago #2
How do I override the template? Do you mean the template included with Minifrontpage Pro?
2 years 2 months ago #3
by SK UP Olomouc
There is a way to customize the function or appearance of a Joomla module called a template override. For Minifrontpage, you can do this by following the steps shown in this video :
Have you ever done this before? If you have ever updated it, then you need to update your template override code as well
2 years 2 months ago - 2 years 2 months ago #4
Last edit: 2 years 2 months ago by TemplatePlazza.
