thumbnails in submaps and thumbnails map
Is it possible to download thumbnails in submaps per month so the folders are not to big?
As example:
2024-11
2024-12
2025-01
etc.
Another question, is it possible to choose own map for the thumbnails? As example images/minifrontpagepro/
1 year 11 months ago #1 by Kees van Norde
Hi Kees,
The thumbnails in Minifrontpage are not something that needs to be kept or stored permanently on the server, as they are only accessed when Minifrontpage requires them. Typically, when new items are added, older items no longer appear in Minifrontpage, which means these thumbnails eventually just become clutter. My recommended practice is to clear the contents of the Minifrontpage Pro thumbnail folder using a cron job. Setting up a cron job indeed requires some technical knowledge, but I recently discovered a scheduled task plugin that can handle this. You can download it here: github.com/TLWebdesignNL/Auto-Delete-Fil...ask-Scheduler-Plugin
I’ll be testing it soon and plan to create a tutorial on how to set it up. If you’d like to try it out right away, feel free to do so.
As for including this feature, it is on my to-do list and will be added in a future update.
1 year 11 months ago #2 by TemplatePlazza
Thanks, I would be a very nice solution.
I will test it soon.
1 year 11 months ago #3 by Kees van Norde
Ok
1 year 11 months ago #4 by TemplatePlazza
This works perfectly!
Perfect, and you don't have to do anything manually anymore :)
Thanks for the tip!
1 year 11 months ago #5 by Kees van Norde
Nice. Thanks for the confirmation
1 year 11 months ago #6 by TemplatePlazza
