Simple Floating Buttons not displaying
- Posted by AegisSales (3) Offline
I have installed Simple Floating Buttons on website 1.
When I installed the module for website 2 it does not display. I have compared the modules on both sites and they both have the same information. Can you please advise.
1 year 9 months ago #1
by AegisSales
It’s probably your template CSS interfering with the module’s CSS. Can you tell me your website URL so I can check it directly?
1 year 9 months ago #2
Hello thank you for the reply
www.gasdetectorshop.com.au
update
I changed the module assignment to display on one page only as well as all pages and it does not display.
The only difference I can see on both sites is that I am testing an ai chat bot on this site that is displaying in the bottom right corner of www.gasdetectorshop.com.au/about/contact-us
1 year 9 months ago - 1 year 9 months ago #3
by AegisSales
update
Last edit: 1 year 9 months ago by AegisSales.
Really sorry, I missed your reply. I have checked your website and tried to open the HTML source, then inspected it. However, I did not find the module installed on your website. Are you sure the module has been published? In what position did you publish it?
1 year 9 months ago #4
Thankyou for your reply.
I am using the debug position but I think I may have chosen the wrong template.
It is now displaying.
Also is there a way to change the hover colour on the button from blue to grey?
Thankyou for taking the time to check this for me.
Jacquie.
1 year 9 months ago - 1 year 9 months ago #5
by AegisSales
Jacquie.
Ah, ok, glad you have found the solution.
1 year 9 months ago #6
simply add this code to the css adjustment tab in the module settings pageAlso is there a way to change the hover colour on the button from blue to grey?
.fab-button:hover {background: grey !important;}Please Log in or Create an account to join the conversation.
