It is perfect!! Many thanks!!!!!
- Posted by Armin Brettschneider (8) Offline
in my site- template the banners with carousel-banner are displayed at left side between the two arrows. Is it possible to center them in the slider? (Attachement)
Armin
1 year 9 months ago - 1 year 9 months ago #1
Armin
Last edit: 1 year 9 months ago by Armin Brettschneider.
Hi, what are the column settings on the module settings page? Can you tell me your website URL so I can check it?
1 year 9 months ago #2
thank you for replying. It´s here: Kamenweb.de - Das Onlinemagazin für Kamen!
It is the Bannerlocation in the mainframe "Werbung" at the top under the Main-Menue.
Armin
1 year 9 months ago #3
Armin
Hmm, it seems that this is because the factual image width is smaller than the container width. Try adding the following code in the CSS adjustment tab on the module settings page:
1 year 9 months ago #4
.tns-item img {width:100%!important;}
