Latestnews + - Date Order
I'm using the "Latestnews +" extesion and I'm very happy with it.
Is there way to change the date order, so the Article text will show first and later the date?
(Check attachment picture)
1 year 8 months ago - 1 year 8 months ago #1 by martini
Last edit: 1 year 8 months ago by martini.
Hi, you can do that by modifying the module's template code via a template override. (If you don't know how to create a template override, please follow this video:
Around line 67, you will see this code:**
<li class="lnpd_item_without_intro" itemscope itemtype="https://schema.org/Article">
<span class="lnpd_item_date">
<?php
//s how date
LatestNewsPlusDateHelper::getDate($show_date, $show_date_type, $item->created, $custom_date_format);
</span>
<a href="<?php echo $item->link; ?>" itemprop="url" class="lnpd_item_title"><span itemprop="name"><?php echo $item->title; ?></span></a>
</li>
change that to :
<?php
//s how date
</span>
</li>
1 year 8 months ago - 1 year 8 months ago #2 by TemplatePlazza
Last edit: 1 year 8 months ago by TemplatePlazza.
Thanks for the feedback.
I have a question about the video, about template overriding
This one goes to a template to override "mod_minifrontpage". I'm usign Joomla 5 and the "Cassiopeia" template. Which mod file should I select to override?
And after that which .PHP file should I modify?
1 year 8 months ago - 1 year 8 months ago #3 by martini
I found it.
It worked. Thanks you very much.
1 year 8 months ago #4 by martini
Ah, okay. Glad you finally found the solution.
1 year 8 months ago #5 by TemplatePlazza
