Carousellbanner Change width for two items
- Posted by Armin Brettschneider (8) Offline
if I want to diplay two banners in my mobile view, the right one alway cut at the right side al little bit. Is there a css-possibility to disply both with full size? I try many things in the settings.
Look in the atachements.
Armin
1 year 8 months ago #1
Armin
Hi, Sorry, the image you attached does not clearly explain the issue. Could you provide a URL to check or a more detailed image?
1 year 8 months ago #2
The mobile view (!) Modulname: "Werbung (2)" at the third Modul on this view. You see two Banners in one Modulposition of Caroussel. The right one is a little bit cut at his right side.
kamenweb.meerbier.de
1 year 8 months ago - 1 year 8 months ago #3
Last edit: 1 year 8 months ago by Armin Brettschneider.
Try to add this code to the CSS adjustment tab :
#carouselbanner-wrp-327 .tns-inner {margin-right:0!important;}
Last edit: 1 year 8 months ago by TemplatePlazza. Reason: removed media query as the issue also exist in desktop view
Thank you for your help, but it is just the same.
1 year 8 months ago - 1 year 8 months ago #6
