Xypo Pro compatibility with Joomla 5.3.0
I would like to know if XTypo Pro is well running with Joomla 5.3.0.
I ask you this question because the system "Pre-Udate Check for Joomla 5.3.0" informs me that XTypo Pro Package has to be updated... Please have a look on the attached screenshot.
Thank you in advance,
Best regards
Pat
1 year 6 months ago #1 by Patrick MATON
HI Pat,
Yes it's running well with Joomla 5.3.0
1 year 6 months ago #2 by TemplatePlazza
Thanks for your quick reply.
Regarding the version of this extension that I installed in my website, could you confirm me that it is well the 1.3.1 or the 1.2.0 version ?
I ask you this question because the 1.2.0 version needs to be updated to allow the installation of Joomla 5.3.0 update.
Thanks in advance for your answer.
Pat
1 year 6 months ago #3 by Patrick MATON
Hi Pat,
Please try downloading and reinstalling the file.
1 year 6 months ago #4 by TemplatePlazza
