MiniFrontpage (Free, Pro) without B/C plugin
- Posted by Peter (20) Offline
On my website MiniFrontpage is the only extention for which I need to activate the B/C compatibility plugin.
Do you have plans to update MiniFrontpage (Pro) so that the B/C plugin can be switched off?
Proposal:
It is not that complicated (I have done it more often), and I could help you with it (for MiniFrontpage Free, because I do not have the PRO version).
In case I have the PRO version, I can also help you with that.
Best regards,
Peter
1 year 2 months ago #1
by Peter
Proposal:
Best regards,
Peter
Hi Peter, Yes, I do plan to work on it. Hopefully by the end of this week I will take a closer look at the possible options. If you could share some guidelines on how you approached on this, that would be very helpful. Thanks
1 year 2 months ago #2
Start with using the component JED Checker
extensions.joomla.org/extension/jedchecker/
) in Joomla and upload the minifrontpage.
Under "Joomla Framework deprecated and unsafe" you see the necessary modifications.
When that is done, the B/C can be switched of.
To make it a native J5 extension, the namespacing and services provider had to be added.
Look in Joomla documentation how that can be done. (I can also do it for you).
Regards,
Peter
1 year 2 months ago #3
by Peter
Regards,
Peter
That's great news!
It works perfectly on my test website without B/C plugin.
Thank you!!
Next step is to make it a native extension with namespacing and a dispatcher class. See the examples in the module directory.
It is not that difficult and it will makes the module ready for the future.
1 year 1 month ago - 1 year 1 month ago #5
by Peter
Thank you!!
Last edit: 1 year 1 month ago by Peter.
