Always visible floating buttons
is there the possibility to keep the floating buttons always visible without having to click on the master one?
thanks.
Claudio
11 months 3 weeks ago #1 by Claudio Tebaldi
Hi Claudio, you need to modify a line in the file /modules/mod_floating_buttons/tmpl/default.php
Find this line (line 17):
<ul id="options<?php echo $module->id; ?>" class="options-list">
Change it to:
<ul id="options<?php echo $module->id; ?>" class="options-list active" style="display: block;">
You can also do that via a template override, please see this video if you want to do that:
11 months 3 weeks ago - 11 months 3 weeks ago #2 by TemplatePlazza
Last edit: 11 months 3 weeks ago by TemplatePlazza.
