Whatsapp Multi agent AI knowledge base
- Posted by Chris Tian (4) Offline
I just installed the latest 2.0 version:
I set everything for IA agent, but I have an issue to add the AI source article.
Nothing happen when I click in the field, and if I manually add the ID in the field, it is not saved.
11 months 5 days ago - 11 months 4 days ago #1
by Chris Tian
Last edit: 11 months 4 days ago by TemplatePlazza.
Hi Chris,
You just need to type the article name, then the option will show up below the field for you to choose.
Please see this video: www.dropbox.com/scl/fi/ohj3964lgyqawiopd...dk&st=xgho2k8z&raw=1
11 months 5 days ago #2
